Старый 09.09.2011, 20:57   #101
tahoe
Аватар для tahoe
Еще ответы на многие вопросы:
Lifting Your Grand:
I want to do this and have it stickied so it is READILY available for those who want to know and don't, so that they don't have to sift through everything and post everything over and over... And allow for people to add to it maybe...
There are 4 basic types of lifts for OUR Grands
1- Budget Boost( BB for future reference)
2- Front to Rear Swap (F>R)
3- Short arm lift(SA lift)
4- Long arm lift(LA lift)
1 The Budget Boost
Commonly called, hockey pucks. They act similar to body lifts(which are NOT available for our Grands). They are round disks that sit on top of the factory or aftermarket springs to add extra height. They don't do anything for suspension travel but will give you a boost in ground clearance. The best things to go along with a BB are shocks, an alignment, and taller tires. THE TALLEST tire you can fit without trimming your fenders is 31s, usually 31x10.5. The tires and shocks are not necessary but the alignment is. You may want to get a track bar bracket or a new adjustable track bar just to help keep your front axle centered. Also, a new steering stabilizer may be needed if you go to taller tires. This is a great kit for beginners or those who have already lifted their Grands and want just a little more height.
2 Front To Rear Swap
This is an inexpensive way to get about a 3" lift out of stock components with fewer addons. It utilizes the factory front springs, which are swapped to the rear and NEW taller front springs are added. Stock control arms are used to keep the price low. Parts that are neccesary are front 3"-3.5" springs, front adjustable track bar or bracket, shocks, and an alignment is a must. What is highly recommended for this type of lift are at least lower control arms and a steering stabilizer. Without at least lower control arms the maximum tire size without trimming would be about a 30" tall tire.
3 The Short Arm lift
Alot more complex than the BB the SA lift involves more parts and time to install. Short arm lifts range in height from 2-4" in height. They can come in either a "Fixed arm" version or an "Adjustable" version. Parts usually included are lower control arms, shocks, front track bar(or bracket depending on the manufacturer), springs, and some times a steering stabilizer. Other parts to consider when doing this lift are upper control arms, Swaybar links or disconnects, rear track bar, steering stabilizer, Slip Yolk Eliminator(for the NP 231 transfer case only--2 WD w/ 4x4 option), extended brake lines, and transfer case drop. On the Adjustable kits you have the adjustable control arms, either upper, lower or both, so that you can adjust your pinion angle to help reduce vibes. About the maximum tire size with 4" of lift and no trimming is a 32x11.5 tire. This is a good kit for begginers and inter-mediate Jeepers who want more than a budget boost and like to moderately wheel their Grands. Also, an alignment should be done.
4 The Long Arm Lift
LA lifts are far more complex and involved than both the SA and BB lifts. I don't know alot about them so I won't go into much detail with this section. The LA lift relocates the control arm mounts to your frame closer to the center of your Grand, reducing control arm angles and allowing for more suspension travel. Most of these kits are weld-in kits and should be installed by professionals. They allow for a higher lift and better ride and provide more adjustability. LA lifts range in height from 4.5" to 7" when sold in kits. You tire size is pretty open as you increase your height or trim your fenders from here.
Steering Upgrades
When lifting a Grand, and adding larger tires some steering upgrades should be made. For slightly or moderately lifted Grands an upgraded stabilizer is a good choice. For moderate-extreme lifted Grands a 1-ton setup or crossover or over the knuckle steering would be a good idea to help reduce bumpsteer and to improve steering geometry.
Axle Upgrades
After having lifted your Grand you can go to a larger tire. With tires up to 32" tall, your axles are ok and may not have to be updated/upgraded depending on your driving habits and/or wheeling style/preference. With a 33" tire and up stock D35 axles are more apt to break under heavy load or wheeling. Gearing should be upgraded at or above 33" tires to maintain driveability. There are several options for upgrading axles as well. Popular options are to swap axles out to D44A or Ford 8.8 or do a Super 35 kit on stock D35s. Super 35 kits which include all things necessary for a 30 spline upgrade along with a locker. The other option, possibly even cheaper, would be to upgrade to a Ford 8.8 or a D44A(which also came stock on some Grands).
Miscillaneous Upgrades
Taller tires and higher lifts affect brakes and their system too. You may look into brakeing upgrades as you get larger tires as your Grand will be harder to stop. EXTENDED brakelines should be used at ANY point when you decide to have your sway bar disconnected and is a good idea with any lift at or above 3"(tho at 3" it is not necessary--unless your sways are disco'ed). The higher your lift is also affects your cornering as well, sway bar upgrades should be taken into consideration as well. Along with taller tires one should consider upgrading your Grand's bumpstops, these will help to prevent your springs from unseating in full flex and help keep your tires from rubbing your fenders in full flex.
Things to Consider
Things to consider when lifting your Grand are: Center of gravity, as you lift your Grand higher, this will raise your center and will make it easier to flip/tip/roll your Grand. Your drive line angles will be increased and will increase wear on you drive line. You may also notice new vibrations after lifting, this is also due to the driveline angles--a transfer case drop or adjustable control arms may HELP correct this. Once you lift your Grand it will be open to our nemesis known as DEATH WOBBLE, this is hard to diagnose and hard to cure. Here is a write up on DWhttp://www.nagca.com/forum/viewtopic.php?t=8730. Another thing to consider, when going to 33" tall tires or taller your axles have a ton of stress added on them and may not stand up to moderate-heavy wheelin, and you may need axle upgrades, like a 30 spline upgrade for your rear axle or an axle swap/conversion. One other thing to consider is that as you lift your Grand the axles are pulled towards each other the higher the lift the closer they come to each other, bringing the tires closer to the fenders, if you have a non-adjustable kit then you will want to be aware of this if you go to a taller lift amount. NOTE: Any type of suspension or steering change warrants an alignment, having an alignment done will help prevent Death Wobble and help the wear pattern on your tires.
Decisions
There is alot out there about lifting and modifying our Grands, do your research and decide which is right for you. I hope this helps anyone who needs it and gets the ball rollin.
Disclaimer
I am NOT an expert nor am I a Jeep tech. This is readily available information that I have found over a couple of years and have learned about Grands. Some of it is opinionated and some of it is factual. I just felt the need to say that.
Jeep Cherokee XJ 4L, 242, 92г.в., Rusty's 4.5", 4:56 gears, TSL 33"
ZJ 4L, 231, 94г.в.,31"
Chevrolet Tahoe 5,7L
tahoe вне форума
Старый 09.09.2011, 21:02   #102
борян
tahoe-Друг-я русский,и я не виноват,что машина американская.
борян вне форума
Старый 09.09.2011, 21:41   #103
tahoe
Аватар для tahoe
Я так же русский, но я крайне рад, что имею американское авто, и я не виноват, что на родине авто, информации в разы больше и она там структурирована, и конкретики больше. выкладываю то что нахожу дабы русские понимающие по англиЦки могли перевести.
как говориться с миру по.... нам рубаха.
tahoe вне форума
Старый 09.09.2011, 23:24   #104
timur_m
Аватар для timur_m
Марка: ZJ 5.2 94 был
Сообщение от tahoe Посмотреть сообщение
кто хорошо шарит по энглишу:
http://www.jeepforum.com/forum/f13/2...budget-555466/
пост по нашим мытарствам, бюджет, Up Country, Monroe....
Может кто отпишет более грамотно, на основе поста - идем уже заказывать в магаз Up Country, Monroe ИЛИ еще думаем :)
Представляю свои выдержки по аммортизаторам под 0-2", что удалось узнать за несколько часов чтения форумов и магазинов в сша.
Короче, всё что продаётся в нашей отсталой стране, а именно в академии+ и клондайке под марками Monroe и KYB - слабенькие устаревшие аммортизаторы. Даже в российском представительстве KYB нет новых крутых амморов, во всю продаваемых в США, написал им запрос: когда и по чём будут
Отсюда и такое отношение к маркам - дешёвые средние или низкокачественные амморы. Но в США картина совершенно другая.
Но сначала немного теории. Для нас интереснее всего аммортизаторы типа mono tube, т.н. однотрубные. Подробнее читайте статью с переводом на русский
Внимание! Нашёл, что новое поколение аммортизаторов mono tube боится сильных ударов, подробнее можно почитать тут - http://translate.google.com/translat...=auto|ru&tbb=1
Из них самые надёжные, известные и популярные в США:
  1. KYB Monomax. Арт. 565053, 565011. http://www.kybcom.ru/monomax.html
  2. Monroe Reflex Monotube. Арт. перед - 911524, зад - 911525
  3. Bilstein Heavy Duty
В США эти амморы идут примерно за одну цену в 60-70$ за штуку.
Так, комплект KYB Monomax, которые мне очень понравились, обойдётся в 235$ плюс 135$ доставка в Россию. Итого 380$ или 11,5 тысяч или почти по 3 тыс. за аммортизатор.
За эти деньги вы получите одни из лучших в США газовых аммортизаторов для наших джипов, рассчитанных под сток и Up Country +1,75". Не нравится KYB? - Получите Bilstein В данном случае ценниг будет почти такой же.
Как видно, доставка к нам очень дорогая, поэтому пинать российских представителей или оптовых покупанов, пусть везут партию!
На экзисте сейчас ценниг на KYB Monomax конский, аж 4 тыс за шт.
Из более бюджетных, чем KYB Monomax очень хвалят амморы Black Diamond - http://www.rockymountainsusp.com/W_s...ackDiamond.htm
В России в продаже не нашёл, на экзисте номера не бьются. Должны быть интересной альтернативой бюджетным KYB Excel-G, описанным ниже.
Более бюджетные амморы, которые есть у нас в продаже:
  1. KYB Амортизатор двухтрубный газовый "Excel-G". Арт. перед - 344088 и старые номера 344392 и 344393. Зад - 344396 и старные номера 344394. В каталоге производителя эти амморы можно ставить на пружину UpCountry с лифтом 1.75". Уверен им будет хорошо и с проставками 2".
    Цена 1800руб в экзисте. За комплект выйдет 7,2 тыр.
У меня получилось так: хочешь хорошие? готовь 12 тыр за комплект. хочешь так себе? готовь 7,2 тыр за комплект.
Теперь вопрос в пружинах. Кто поделится опытом, какие пружины брать под 2", если их менять всёравно надо и есть проставки 2"?
Последний раз редактировалось timur_m; 10.09.2011 в 03:27.
timur_m вне форума
Старый 10.09.2011, 00:43   #105
Soldat
Аватар для Soldat
Марка: Grand Cherokee '95 Orvis Edition 5.2 V8 ПРОДАН. Теперь Chevrolet K5 Blazer
timur_m, спасибо за инфу, очень интересный анализ!
По пружинам, возможно, будет полезной инфа из той же библии Партнамберы, жесткость и высота одной и той же машины при разных пружинах там указана.
Установка жестких пружин #52089145 rear усиленная, код JJ, дает пприбавку в высоте в 3,5 см по сравнению со стандартом. То есть 1,4 дюйма можно получить без колхоза используя новые штатные пружины.
Последний раз редактировалось Soldat; 10.09.2011 в 00:53.
Soldat вне форума
Старый 10.09.2011, 03:24   #106
timur_m
Аватар для timur_m
Сообщение от timur_m Посмотреть сообщение
нашёл, что новое поколение аммортизаторов mono tube боится сильных ударов, что нас должно настораживать. подробнее можно почитать тут - http://translate.google.com/translat...=auto|ru&tbb=1
буду рад, если кто что добавит..
timur_m вне форума
Старый 10.09.2011, 03:28   #107
timur_m
Аватар для timur_m
Сообщение от Soldat Посмотреть сообщение
спасибо, буду вкуривать
timur_m вне форума
Старый 10.09.2011, 05:15   #108
timur_m
Аватар для timur_m
Вот ещё, нашёл статью о том, как чел на 5.9 нашёл и поставил пружины и амморы от легендарной орвисовской подвески "UpCountry" (+1,75"), для вас с переводом
Оказывается, в UpCountry стоят крутые амморы Sachs-Boge monotube Ценниг на них конский, конечно, но и орвисов с новой подвеской в продаже нет
timur_m вне форума
Старый 10.09.2011, 05:41   #109
timur_m
Аватар для timur_m
Прикольно, в библии есть Monroe Reflex Monotube - http://jeep.avtograd.ru/Grand_Cherok...or_lifting.htm
но там нет KYB Monomax
timur_m вне форума
Старый 10.09.2011, 05:50   #110
timur_m
Аватар для timur_m
Вот тут прикольный спор продавца крутых монотубовых амморов (Kolak) и приверженца black diamond (Buc..). Оказывается любитель BD перепробовал до этого дорогие монотубные аммы и остался на BD. Найти бы их в продаже в России , в пендосии они по 25$
timur_m вне форума
Текущее время: 13:00. Часовой пояс GMT +3.
