09.06.2015, 22:42 | #1 |
Распиновка проводки к магнитоле XJ
Подключение магнитолы на XJ разных годов, возможно кому понадобится:
http://snowboard247.blogspot.ru/2005...ring-info.html http://www.the12volt.com/installbay/...tail/1150.html 1984-01 Jeep Cherokee (XJ) Wiring Info. 1984 Jeep Cherokee Stereo Information Constant 12V+ Red/White Switched 12V+ Purple/White Ground Black Illumination Blue/Red Dimmer Orange/Black Front Speakers Left Front (+) Gray Left Front (-) Brown/Red Right Front (+) White/Red Right Front (-) Yellow Rear Speakers Left Rear (+) Gray/White Left Rear (-) Brown Right Rear (+) White/Black Right Rear (-) Brown/White 1984 Jeep Cherokee Ignition Information Constant 12V+ [Red] Ignition Switch Harness Starter Dark [Green] Ignition Switch Harness Ignition [Yellow] Ignition Switch Harness Accessory [Brown] Ignition Switch Harness Tach [Green] Coil Brake Switch [White] Brake Switch Trunk Pin [Black (-)] Rear Light Parking Lights [Dark Blue] Light Switch Hood Pin n/a Factory Disarm n/a Door Trigger [Black(-)] Driver's Pin Switch Door Lock [White] Driver's Kick Panel Door Unlock Dark [Green] Driver's Kick Panel (Reverse Polarity) 1985-87 Jeep Cherokee Stereo Information Constant 12V+ Red/White Switched 12V+ Purple/Orange Ground Black Dimmer Orange/Black Antenna Trigger Gray Front Speakers Left Front (+) Green Left Front (-) Black/White Right Front (+) White Right Front (-) Black Rear Speakers Left Rear (+) Green/White Left Rear (-) Brown/White Right Rear (+) White/Black Right Rear (-) Brown 1985-87 Jeep Cherokee Ignition Information Constant 12V+ [Red] Ignition Switch Harness Starter Dark [Green] Ignition Switch Harness Ignition [Yellow] Ignition Switch Harness Accessory [Brown] Ignition Switch Harness Tach [Green] Coil Brake Switch [White] Brake Switch Trunk Pin [Black (-)] Rear Light Parking Lights [Dark Blue] Light Switch Hood Pin n/a Factory Disarm n/a Door Trigger [Black (-)] Driver's Pin Switch Door Lock [White] Driver's Kick Panel Reverse Polarity Door Unlock [Dark Green] Passenger's Kick (+) Door Unlock [W/Keyless Light Green and Tan] Passenger's Kick (+) Horn Wire [Black (-)] Steering Column 1988-90 Jeep Cherokee Stereo Information Constant 12V+ Pink Switched 12V+ Purple/Orange Ground Black Illumination Orange/Black Dimmer Dark Blue/White Antenna Trigger Gray Front Speakers Left Front (+) Green Left Front (-) Black/Yellow Right Front (+) White Right Front (-) Black Rear Speakers Left Rear (+) Gray/White Left Rear (-) Brown/White Right Rear (+) White/Black Right Rear (-) Brown 1988-90 Jeep Cherokee Ignition Information Constant 12V+ [Red] Ignition Switch Harness Starter Dark [Green] Ignition Switch Harness Ignition [Yellow] Ignition Switch Harness Accessory [Brown] Ignition Switch Harness Tach [Green] Coil Brake Switch [White] Brake Switch Trunk Release [Black/White] Manual Release Trunk Pin n/a Works with Dome Light Parking [Lights Blue (+)] Light Switch Hood Pin n/a Factory Disarm n/a Door Trigger [Black/White (-)] Light under Dash Door Lock [White] Driver's Kick Panel Reverse Polarity Door Unlock [Dark Green] Passenger's Kick (+) Door Unlock [W/Keyless Light Green and Tan] Passenger's Kick (+) Horn Wire [Black (-)] Steering Column Windows Up [LF=Light Blue, RF=Brown/White] Windows Down [LF=White, RF=Purple/White] 1988-90 Jeep Cherokee Cruise Information Constant 12V+ [Red] Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ [Yellow] Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake [n/a] Brake Switch Cold Side of Brake [White] Brake Switch Tach Green Coil VSS Lead [White/Orange] Harness from Transmission Pulses Per Mile 8000 PPM Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 1991-92 Jeep Cherokee Stereo Information Constant 12V+ Red/White Switched 12V+ Purple/White Ground Black Illumination Blue/Red Dimmer Red/Black Antenna Trigger Purple/Orange Front Speakers Left Front (+) Gray Left Front (-) Yellow Right Front (+) White/Red Right Front (-) Brown/Red Rear Speakers Left Rear (+) Gray/White Left Rear (-) Brown/White Right Rear (+) White/Black Right Rear (-) Brown 1991-92 Jeep Cherokee Ignition Information Constant 12V+ [Red] Ignition Switch Harness Starter [Yellow/Green] Ignition Switch Harness Ignition [Blue] Ignition Switch Harness Accessory [Purple] Ignition Switch Harness Tach [Green] Coil Brake Switch [White] Brake Switch Trunk Pin [n/a] Works with Dome Light Parking Lights [Blue/Red] Driver's Kick Panel Head Lamp [Brown/Black] Left of Steering Column Hood Pin [n/a] Factory Disarm [Green/Orange] (-) Driver's Kick Panel Door Trigger [Yellow (-)] Light under Dash Door Lock [Orange/Purple] Driver's Kick Panel Door Unlock [Pink/Purple] Positive Trigger Horn Wire [Black (-)] Steering Column 1991-92 Jeep Cherokee Cruise Information Constant 12V+ [Red] Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ [Blue] Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake [n/a] Brake Switch Cold Side of Brake [White] Brake Switch Tach Green Coil VSS Lead [White/Orange] Wire Harness from Transmission Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 1993-94 Jeep Cherokee Stereo Information Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Trigger Purple/Orange Front Speakers Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange 1993-94 Jeep Cherokee Ignition Information Constant 12V+ [Red/White] Ignition Switch Harness Starter [Yellow/Blue] Ignition Switch Harness Ignition [Blue/White] Ignition Switch Harness Accessory [Black/Orange] Ignition Switch Harness Tach [Black/Gray Or Black/White (-)] At Coil Brake Switch [White] Brake Switch Trunk Pin [n/a] Works with Dome Light Parking Lights [Blue/Red] Driver's Kick Panel Black Connector Head Lamp [Brown/Black] Left of Steering Column Hood Pin [n/a] Factory Disarm [Purple/Yellow (-)] Driver's Kick Panel Door Trigger [Yellow (-)] Light under Dash Door Lock [Orange/Purple] Driver's Kick Panel Gray Connector Door Unlock [Pink/Purple] Positive Trigger Horn Wire [Black (-)] Steering Column Windows Up LF=White, RF=Brown/White 1993-94 Jeep Cherokee Cruise Information Constant 12V+ [Red/White Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ [Blue/White] Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake [n/a] Brake Switch Cold Side of Brake [White] Brake Switch Tach [Black/Gray Or Black/White (-)] At Coil VSS Lead White/Orange In Wire Harness from Transmission Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 1995-96 Jeep Cherokee Stereo Information Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Front Speakers Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange 1995-96 Jeep Cherokee Ignition Information Constant 12V+ [Red/White] or Red Ignition Switch Harness Starter [Yellow/Blue or Yellow] Ignition Switch Harness Ignition [Blue/White or Blue] Ignition Switch Harness Ignition 2 [Purple] Ignition Switch Harness Accessory [Black/Orange] Ignition Switch Harness Tach [Black/Gray Or Black/White (-)] At Coil Neutral Safety Wire Brown/Yellow (-) Switch on Transmission Brake Switch [White] Brake Switch Trunk Release [Pink/Black (+)] Driver's Kick Panel Rear Body Harness Trunk Pin [n/a] Works with Dome Light Parking Lights [Blue/Red] Driver's Kick Panel Black Connector Head Lamp [Tan/Black (+)] Light Switch Hood Pin [n/a] Factory Disarm [Purple/Yellow (-)] Driver's Kick Panel or Pin 10 BCM lower left Instrument Panel Door Trigger [Yellow (-)] Light under Dash Door Lock [Orange/Purple] Driver's Kick Panel Gray Connector Door Unlock [Pink/Purple] Positive Trigger Horn Wire [Black/Red (-)] Steering Column Windows Up [LF=White, RF=Brown/White, LR=Blue/White, RR=Green/White] Windows Down [LF=Light Blue, RF=Purple/White, LR=Red/Black, RR=Gray/Black] 1995-96 Jeep Cherokee Cruise Information Constant 12V+ [Red/White or Red] Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ [Blue/White or Blue] Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake [n/a] Brake Switch Cold Side of Brake [White] Brake Switch Tach [Black/Gray Or Black/White (-)] At Coil VSS Lead White/Orange In Wire Harness from Transmission Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 1997-01 Jeep Cherokee Stereo Information Constant 12V+ Pink/Yellow Switched 12V+ Red/White Ground Black Illumination Orange/Brown Dimmer Black/Light Blue Front Speakers Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange 1997 Jeep Cherokee Ignition Information Constant 12V+ Red/White or Red Ignition Switch Harness Starter Yellow/Blue or Yellow Ignition Switch Harness Ignition Blue/White or Blue Ignition Switch Harness Ignition 2 Black/Orange Ignition Switch Harness Accessory Black/White Ignition Switch Harness Tach Gray Coil Neutral Safety Wire Brown/Yellow (-) Switch on Transmission Brake Switch White/Green Brake Switch Trunk Release Pink/Black (+) Driver's Kick Panel Rear Body Harness Trunk Pin Gray/Black (-) Hatch Back Switch Parking Lights Black/Yellow (+) Light Switch Head Lamp Light Green (+) Light Switch Door Trigger Yellow (-) Light under Dash Door Lock Pink/Purple (-) Either Kick Panel Door Unlock Orange/Purple (-) Horn Wire Black/Red (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White 1997 Jeep Cherokee Cruise Information Constant 12V+ Red/White or Red Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ Blue/White or Blue Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake n/a Brake Switch Cold Side of Brake White/Green Brake Switch Tach Gray Coil VSS Lead White/Orange PCM, Passenger's Firewall,32 Pin Plug Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 1998 Jeep Cherokee Ignition Information Constant 12V+ Red/White Steering Column Starter Yellow Low Current Ignition Switch Harness at Steering Column Ignition Blue/Gray Ignition Switch Harness Ignition 2 Black/Orange Ignition Switch Harness Accessory Black/White Ignition Switch Harness Tach Gray/White In Black Connector at PCM Neutral Safety Wire Brown/Yellow (-) Switch on Transmission Brake Switch White/Tan Brake Switch Trunk Release Pink/Black (+) Driver's Kick Panel Rear Body Harness Trunk Pin Tan/Black (-) BCM Parking Lights Dark Blue/Red (+) Left Kick Panel or Light Switch Head Lamp Tan/Black (+) Light Switch Factory Disarm Purple/Yellow Driver's Kick Panel Door Trigger Yellow (-) Light under Dash Door Lock Orange/Purple (-) Driver's Door/Orange/Black Passenger's Door Door Unlock Pink/Black (-) Driver's/Passenger's Doors Horn Wire Black/Red (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Black/White, RR=Gray/Black Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White 1998 Jeep Cherokee Cruise Information Constant 12V+ Red/White Steering Column or Use Hot Side of Brake Switched 12V+ Blue/Gray Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake n/a Brake Switch Cold Side of Brake White/Tan Brake Switch Tach Gray/White In Black Connector at PCM VSS Lead White/Orange PCM, Passenger's Firewall,32 Pin Connector Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 1999 Jeep Cherokee Ignition Information Constant 12V+ Pink/Black or Red Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Blue Ignition Switch Harness Ignition 2 Black/Orange Ignition Switch Harness Accessory Black/White Ignition Switch Harness Tach Gray Coil Neutral Safety Wire Yellow (+) Ignition Switch Brake Switch White/Tan Brake Switch Trunk Release Pink/Black (+) Driver's Kick Panel Rear Body Harness Trunk Pin Tan/Black (-) BCM Parking Lights Black/Yellow (+) Light Switch Head Lamp Purple/White (+) 26 Pin Connector Passenger's Kick Position S3 Junction BL Factory Disarm Purple/Yellow Driver's Kick Panel Door Trigger Yellow (-) Under Dash Light or Overhead Module Door Lock Orange/Purple (-) Driver's Kick Panel Door Unlock Pink/Purple (-) Must use Relays Driver's Lock Blue Driver's Unlock Blue/Red Horn Wire Black/Red (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White 1999 Jeep Cherokee Cruise Information Constant 12V+ Pink/Black or Red Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ Blue Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake n/a Brake Switch Cold Side of Brake White/Tan Brake Switch Tach Gray Coil VSS Lead White/Orange 32 Pin Connector Position B27 PCM left Side Engine Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. 2000-01 Jeep Cherokee Ignition Information Constant 12V+ Red Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Blue Ignition Switch Harness Ignition 2 Black/Orange Ignition Switch Harness Accessory Black/White Ignition Switch Harness Tach Gray Coil Neutral Safety Wire Yellow (+) Ignition Switch Brake Switch White/Tan Brake Switch Trunk Release Pink/Black (+) Driver's Kick Panel Rear Body Harness Parking Lights Black/Yellow (+) Light Switch Head Lamp Purple/White (+) 26 Pin Connector Passenger's Kick Position S3 Junction BL Factory Disarm Purple/Yellow Driver's Kick Panel Door Trigger Yellow (-) Under Dash Light or Overhead Module Door Lock Orange/Purple (-) Driver's Kick Panel Door Unlock Pink/Purple (-) Must use Relays Driver's Lock Orange/Black Junction Block Driver's Unlock Pink/Black Junction Block Horn Wire Black/Red (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White 2000-01 Jeep Cherokee Cruise Information Constant 12V+ Red Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ Blue Ignition Switch Harness Ground Use Chassis Near Cruise Control Module Hot Side of Brake n/a Brake Switch Cold Side of Brake White/Tan Brake Switch Tach Gray Coil VSS Lead White/Orange 32 Pin Connector Position B27 PCM left Side Engine Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Jeep Cherokee XJ 4L, 242, 92г.в., Rusty's 4.5", 4:56 gears, TSL 33" ZJ 4L, 231, 94г.в.,31" Chevrolet Tahoe 5,7L |
