Старый 21.05.2010, 09:29   #11
Fazerovod
Марка: JEEP Wrangler
Вот что ответили америкосы с АирЛифта на мой запрос:
Hello,
Thank you for your inquiry.
What is your desire for this air ride?
This kit will allow you to lower the vehicle down and up with 7" of travel. Each air spring can carry 2500lbs.
FBSS KIT CONTENTS :
FRONT AIR KIT (INCLUDES AIRBAGS & MOUNTING BRACKETS)
REAR AIR KIT (INCLUDES AIRBAGS & MOUNTING BRACKETS)
3 GALLON HIGH-PRESSURE AIRTANK(OPTIONAL 5GALLON IRTANK)
COMPRESSOR PSI CUT-OFF SWITCH
3/4HP COMPRESSOR 100% DUTY CYCLE 180PSI MAX(SEALED COMPRESSOR)
4 WAY ELECTRIC AIR-VALVE SETUP 3/8" 160PS(INDEPENDENT CORNER CONTROL)
3/8 HI-PRESSURE AIRHOSE & FITTING KIT
4 FAST RESPONSE SWITCH-PANEL(OPTIONAL 10-SWITCH CONTROL UPGRADE UPON REQUEST)
(2) LIGHTED PSI GAUGES(OPTIONAL DIGITAL GAUGE UPGRADE UPON REQUEST)
*ALL PARTS WILL BE MOUNTED ON A PLATFORM FOR EASY INSTALL AND CLEAN LOOK
*2-3 SECOND INFLATION/DEFLATION TIME
*4-CORNER CONTROL(FRONT-BACK, SIDE-SIDE, 4-CORNER INDIVIDUAL, AND PANCAKE)
Fazerovod вне форума
Текущее время: 03:02. Часовой пояс GMT +3.
