Старый 07.04.2011, 21:29   #1
admin
Аватар для admin
Марка: cherokee XJ 2D
По умолчанию фото раллийных JEEP
Suspension:
Front: RE1345 – Coil Springs, King 12”x 2.5” Triple Bypass shocks, Fox 2” Hydro Bumps, strap limited to 10” travel
Currie; CE-9701 Currectlync HD steering, CE-9037X Steering gear box brace, CE-9120HD Trac bar, CE-9102 Upper control arms
Skyjacker; 6”Subframe and lower arms with Currie JJ ends
Rear: Deaver “Jeepspeed Race Pack”, King 16”x 2.5” Tripple Bypass shocks, solid rear bump stop, strap limited to 12” travel
Wheels/tires :
33x10.50-15" BF Goodrich Baja TAs
15”x8” BLACKROCK Desperados
Axles/Suspension:
Dana 30 front axle, trussed custom mounts, Detroit Locker, 4.88 gears custom 6 lug dana 44 hub conversion and brakes
Rubicon Express long arms, custom crossmember
Rubicon Express 5.5' coil springs
King 2.5"x12" double bypass shocks, strapped at 13" of travel
Radflo 2"x4" hydraulic bump stops
Ford 9 inch rear axle, trussed
31 spline Dutchman chro-moly axle shafts
4.88 gears, Detroit Locker, disc brakes
4 link trailing arm suspension, 1 1/4" heims everywhere, except bushings at frame side of lowers
King 2.5"x14" coilovers
FOA 2.5"x16" triple bypass shocks, strapped at 18" of travel
37x12.50 17 BFG KR project race tires or 36x13.50 16 Interco Irok's
front:
JCR prerunner bumper
2 6" procomp lights converted to HID
4.5" fabtech coils
1.75 poly spacers
hanneman flat top 6" bulge glass fenders
blown out crappy procomp resevoir shocks
fabtech lower arms
stock uppers
procomp trackbar w/ 5/8" heim at the frame end
rear:
detours USA rear bumper
RE 4" leafs
generic 2" shackles
rear shock hoop
14" King 2.5" prerunner series smooth body resevoir shocks
33x10.50x15 BFG Baja T/A tires
131_0605_01_z+baja_1994_jeep_grand_cherokee+jump.jpg   880964065_dsc_5895.jpg   IMG00154-20100803-1205.jpg   jeep1.jpg   jeep2.jpg
CIMG4001.jpg   19944_328617391013_327237661013_5252258_3918536_n-1.jpg   ParkerJump3.jpg   ParkerJump5.jpg
JEEP-Forum - Мы объединяем...
эпичные цитаты pirate4x4.com:
Go Big or go home ! (....)
info@jeep-forum.ru
Последний раз редактировалось admin; 07.04.2011 в 22:08.
admin вне форума
Старый 07.04.2011, 22:13   #2
KVAkk
Марка: YJ 2.5
Спасибо! ..Но все же рэнга бы посмотреть...;)))) Тот, судя по видео, совсем под другой тип гонок подготовлен, хотя могу и ошибаться.
KVAkk вне форума
Старый 07.04.2011, 22:17   #3
admin
Аватар для admin
вот этот рэнг как сделан
http://www.jeepspeed.net/smf/index.php?topic=442.0
249-baja1k-re-size_001.jpg   249-baja1k-re-size_002.jpg   0812_4wd_15_z+1998_jeep_wrangler_desert_race_car+coilover_shocks.jpg   0812_4wd_16_z+1998_jeep_wrangler_desert_race_car+suspension_links.jpg   0812_4wd_17_z+1998_jeep_wrangler_desert_race_car+rear_axle.jpg
info@jeep-forum.ru
Последний раз редактировалось admin; 07.04.2011 в 23:18.
admin вне форума
Старый 07.04.2011, 22:29   #4
admin
Аватар для admin
в постройке раллийной подвески очень много нюансов на которые трофисты кладут болт... и в лучшем случае трофейная машина способна быстро (80-100км\ч) ехать прямо... на них лучше не поворачивать ;)
info@jeep-forum.ru
admin вне форума
Старый 07.04.2011, 22:34   #5
KVAkk
Марка: YJ 2.5
Вот кстати альтернативный вариант (это правда видео, но всеж немножко видно):
http://www.youtube.com/watch?v=iLOK_...eature=related
KVAkk вне форума
Старый 07.04.2011, 22:40   #6
admin
Аватар для admin
вот развлекайся
http://jeepspeed.com/
http://www.google.ru/search?q=jeepsp...ed=0CBYQ_AUoAQ
info@jeep-forum.ru
admin вне форума
Старый 07.04.2011, 22:49   #7
admin
Аватар для admin
если планируются "полеты" то бамп стопы нужны, а так 4,5" лифт, аммы и работа с углами мостов... тк кастор нужно увеличивать... те нужно шаровые наклонять назад относительно редуктора и тд
обрати внимание на мост
они его поворачивают, а потом уши обратно приваривают, а трофисты лохи этого не делают, по тому что это доволно сложная процедура ;)
info@jeep-forum.ru
admin вне форума
Старый 08.04.2011, 00:06   #8
KVAkk
Марка: YJ 2.5
Огромное спасибо! Читаем-с насколько языка хватает))
KVAkk вне форума
Старый 08.04.2011, 15:21   #9
KVAkk
Марка: YJ 2.5
АААА! ААААААААААААААА!!! АААААААААААААААААААААААААААААА!!!!!!!!
Вроде выговорился... Нет, еще не все...
Вот теперь все... Чтоб я так жил... У меня органов на продажу не хватит
Улыбаюсь и немного плачу..
Последний раз редактировалось samoroshka; 09.04.2011 в 11:46.
KVAkk вне форума
Старый 08.04.2011, 15:38   #10
admin
Аватар для admin
не расстраивайся, на подвеску надо примерно 100тр. + работа с мостами привода, блокировки, ступицы и тд... еще 120тр+ работы по установки и доработки итого 300тр и у тебя настоящая не убиваемая раллийная подвеска для низких полетов над землей... копи бабло
можно конечно и бюджетно, но тогда без полетов...
info@jeep-forum.ru
admin вне форума
Текущее время: 21:15. Часовой пояс GMT +3.
