Старый 02.02.2013, 16:58   #21
lavkonk
Аватар для lavkonk
Марка: Был WJ 2001г рк 242 4.0, хочу 2003-2004:)
мне нужен джип который я написал расход до 20 устраивает,
что про этот скажите??а то я не очень разбираюсь, помогите если не сложно))))))))
1: Built By Chrysler Corp
J: Jeep
4: Multipurpose Passenger Vehicle
G: 5001 - 6000# (2268 - 2721 kg) GVWR & Hyd. Brakes
W: Grand Cherokee (4x4) (Left Hand Drive)
B: 4 Spd Auto (DGB)
8: Sport Utility 4 dr.
N: 4.7L 8 CYL Gasoline (MPI) (EVA)
5: Check digit
X: Model Year 1999
Y: STEYR ASSEMBLY
Код модели кузова: WJJL74
Двигатель: EVA 4.7L V8 MPI Engine
Коробка передач: DG4 Multi-Speed Auto 45RFE Transmission
Модельный год: 1999
Дата производства: 04.02.1999
*EL: Leather Trimmed Bucket Seats
-AZ: Agate
0YVA: FAM
106S: Zone 06-Export
1AUS: Export Homologated
28G: Customer Preferred Package 28G
2TGA: Customer Preferred Package 2TG
3D2A: Intl. Price Protection B
3HGA: Coso Wt. & D.M.
3HMA: Coso Spbr Not Required
3HQA: Market Homologation
3HWA: Export Ocean Freight
3HZA: Export Insurance
4ALA: 1NTL 37 DAY SCHEDULE
4HA: Special Scheduling Condition I
4HC: Special Scheduling Condition III
4XTA: Delete Domestic Warranty Manual
4YBA: Export Option Requirements
5IUS: GA-Vehicle Family
5IWS: JS-Vehicle Family
6CTP: Certificate of Conformance
6EMP: Label - European E Mark
6MPP: Plate - Manufacturer
895A: European Region
8CJA: Germany Country Code
A29P: 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
ABBA: European Equipment Group
ABES: Export Equipment Group
ADBP: Protection Group
AEJP: Silver Group
AFFP: Luxury Group
AHRP: 3500 KG. Trailer Tow Group
APAS: Monotone Paint
ARPP: Limited Decor Group
AWSS: Smoker's Group
BAZS: 136 Amp Alternator
BC6S: 625 Amp Maintenance Free Battery
BRYS: Anti-Lock 4-Wheel Disc Brakes
CACS: Low Back Bucket Seats
CBWS: Highline Door Trim Panel
CFNS: Rear 60/40 Folding Seat
CGWS: Next Generation Front Air Bags**
CKDS: Floor Carpet
CKNS: Cargo Compartment Carpet
CKRP: Cargo Net
CKTS: Cargo Tie Down Loops
CLEP: Front & Rear Floor Mats
CLGP: Covered Cargo Storage
CLPS: Door Sill Scuff Pads
CSCP: Cargo Compartment Cover
CSRS: Passenger Assist Handles
CUDP: Mini Overhead Console
CUFS: Full Length Floor Console
DG4S: Multi-Speed Auto 45RFE Transmission
DGB: All 4-Speed Automatic Transmissions
DHAS: Lock-Up Torque Converter
DHFS: Quadra-Trac II On Demand 4WD System
DJJS: Dana 30/186MM Front Axle
DMEP: 3.73 Axle Ratio
DRKS: Dana 44/226MM Rear Axle
EAAC: All Engines
EVA: 4.7L V8 MPI Engine
GBBS: Tinted Windshield Glass
GCBS: Front Door Tinted Glass
GEDS: Tinted Rr Drs/Qtr/Liftgate Glass
GEPS: Flipper Liftgate Glass
GFAS: Rear Window Defroster
GNCP: Sun Visors w/Illum Vanity Mirrors
GNKP: Rear View Auto Dim Mirror
GTFP: Power Mirrors
GWA: Power Sunroof
GXMS: Remote Keyless Entry
GXXP: Sentry Key Theft Deterrent System
HAFP: Air Cond ATC w/Dual Zone Control
HGAS: Hood Insulation
HGDS: Deluxe Insulation Group
JAYS: Instrument Cluster w/Tach
JDHS: 230 KPH Primary Speedometer
JHAS: Var Intermittent Windshield Wipers
JHBS: Rear Window Wiper/Washer
JJAS: Cigar Lighter
JJBS: Dual Note Electric Horns
JJJP: 12V Auxiliary Power Outlet
JKAS: Locking Glove Box
JKLP: Headlamp Leveling System
JKPS: 12V Auxiliary Power Outlet
JKYS: Power Accessory Delay
JPBS: Power Locks
JPDS: Power Windows, Driver One-Touch
JTF: Power 10-Way Heated Memory Seats
K4HS: STRIPE/BADGE/MOLDING/COLOR
KEDP: STRIPE/BADGE/MOLDING/COLOR
KRSS: STRIPE/BADGE/MOLDING/COLOR
KSSP: STRIPE/BADGE/MOLDING/COLOR
KTSS: STRIPE/BADGE/MOLDING/COLOR
KUSP: STRIPE/BADGE/MOLDING/COLOR
KWSS: STRIPE/BADGE/MOLDING/COLOR
LACS: Illuminated Entry
LAGS: Warning Chime
LAZP: Vehicle Information Center
LBBS: Courtesy Lamps
LBCS: Glove Box Lamp
LBDS: Ash Tray Lamp
LCBP: Door Courtesy Lamps
LCES: Rear Courtesy/Reading Lamps
LDAS: Underhood Lamp
LDBS: Cargo Compartment Lamp
LETP: Traveler/Mini Trip Computer
LEWP: Radio/Driver Seat/Mirrors Memory
LMJS: Halogen ECE Headlamps
LNJP: Fog Lamps
LPSS: CHMSL Lamp
LSAS: Security Alarm
MDAP: Front License Plate Bracket
MFTP: Body Color Grille
MHAS: Black Windshield Moldings
MWGS: Roof Rack
NACS: European II Emissions
NFPS: 20.5 Gallon Fuel Tank
NHBP: Auxiliary Transmission Oil Cooler
NHFP: Power Steering Cooler
NHMS: Speed Control
PAW: Deep Slate Pearl Coat
QAWS: Dark Slate Pearl Coat
RAAC: All Radio Equipped Vehicles
RBLS: AM/FM Cass Radio w/Changer Control
RCES: Infinity Speakers
RDLS: Integrated in Rear Window Antenna
RDP: 10-Disc Remote CD Changer
SBAS: Power Rack and Pinion Steering
SCLP: Leather Wrapped Steering Wheel
SDAS: Normal Duty Suspension
SUAS: Tilt Steering Column
TBLS: Inside Mounted Spare Tire
TBWS: Full Size Matching Whl Spare Tire
TTEP: 245/70HR16 BSW All Season Tires
TZAS: Goodyear Brand Tires
WDRP: 16X7.0 Lux Alum Silver Wheels
WLZC: All Aluminum Wheels
XEVP: Tow Eye Brackets
XJHS: Locking Fuel Filler Cap
XPFS: Protective Coating and Remover
YABS: Build To Export Mkt. Specifications
YGAA: Without Billable Fuel
YHRA: 1.3 Additional Gallons of Gas
Z6BP: GVW/Payload Rating
ZKGP: Spring - Left Front
ZKYP: Spring - Left Rear
ZYGP: Spring - Right Front
ZYYP: Spring - Right Rear
lavkonk вне форума
Старый 02.02.2013, 17:06   #22
Dorognik
Аватар для Dorognik
курите "библию" для начала,все там описано в доступной форме,а если так уж хочется квадра-драйв то нужно его и искать,только учтите,что блокировки скорее всего уже убитые и надо брать ремкомплект и менять,а не дай Бог еще и муфта в 247....вот этим лучше озадачится при выборе авто..а задавать вопросы из серии,"что лучше автомат али пулемет" а потом еще и обижаться не стоит.
Dorognik вне форума
Старый 02.02.2013, 17:08   #23
КУБАНЕЦ
Аватар для КУБАНЕЦ
Марка: Вжик 4,7
Сообщение от lavkonk Посмотреть сообщение
Гыыыы!) такой расход на 4,7 - impossible!
В указанной комплектации мосты со свободными дифами.
И ваще, начинаем с библии:
http://jeep.avtograd.ru/Grand_Cherokee/WJ/index.htm - в целом
http://jeep.avtograd.ru/Grand_Cherokee/WJ/xfer.htm - раздатки
http://jeep.avtograd.ru/Grand_Cherokee/WJ/axles.htm - мосты
КУБАНЕЦ вне форума
Старый 02.02.2013, 17:11   #24
alekssandr
летом при спокойной езде у мня 17-18 кушал...при обычной 21...зимой 23
alekssandr вне форума
Старый 02.02.2013, 17:11   #25
lavkonk
Аватар для lavkonk
со свободными дифами?это значит нет никаких блокировок?
lavkonk вне форума
Старый 02.02.2013, 17:13   #26
КУБАНЕЦ
Аватар для КУБАНЕЦ
Марка: Вжик 4,7
средний или городской режим? У него по паспорту в городе 22...
http://www.wjjeeps.com/rus/engine.htm
КУБАНЕЦ вне форума
Старый 02.02.2013, 17:15   #27
lavkonk
Аватар для lavkonk
вообще ктото разбирается в джипах можете посоветовать путное?я всё читал плохо ещё разбираюсь, когда куплю разберусь но возможно будет позно.....
вот это что за джип хочу на него поменяться, написано все блокировки есть...стоит того или нет??
http://cars.auto.ru/cars/used/sale/35575824-6ed6.html
lavkonk вне форума
Старый 02.02.2013, 17:20   #28
КУБАНЕЦ
Аватар для КУБАНЕЦ
Марка: Вжик 4,7
Это гранд широкий! Откуда мы знаем стоит он или нет? Аборт по телефону? Бери в помощь сведущего (может с форума) и гоу на осмотр авто!
КУБАНЕЦ вне форума
Старый 02.02.2013, 17:23   #29
КУБАНЕЦ
Аватар для КУБАНЕЦ
Марка: Вжик 4,7
"Обычный («свободный») дифференциал отлично работает, пока ведущие колёса неразрывно связаны с дорогой. Но, когда одно из колёс оказывается в воздухе или на льду, то крутится именно это колесо, в то время как другое, стоящее на твёрдой земле, теряет всякую силу." (с)
http://ru.wikipedia.org/wiki/%C4%E8%...E0%ED%E8%EA%E0)
КУБАНЕЦ вне форума
Старый 02.02.2013, 17:29   #30
lavkonk
Аватар для lavkonk
ну и нафиг мне свободный диференциал....блин надо что путное...на 242 раздатке я понял вообще ловить нечего никаких блокировок ещё и мост отключаемый
lavkonk вне форума
Текущее время: 22:20. Часовой пояс GMT +3.
