Старый 02.08.2013, 20:56   #1
александр волков
Марка: ДЖИП ЛИБЕРТИ
По умолчанию Подскажите чайнику!!!
Какое масло лить в мосты?Сколько? Какие они?Вот вин 1J4GL48595W635178.
александр волков вне форума
Старый 03.08.2013, 04:39   #2
Андрюха
Аватар для Андрюха
Марка: KJ '03 Limited 3.7 - был
1: Manufactured By DaimlerChrysler Corporation
J: Jeep
4: Multipurpose Passenger Vehicle w/out Side Air Bags
G: 5001-6000# (2268-2721 KG) GVWR & Hyd. Brakes
L: Liberty/Cherokee Left Hand Drive (4x4) Less "ABB"
4: Liberty SPORT (US, Can, Mex)(Cherokee SPORT BUX)
8: Hatchback/Tall/Sport/Quad Cab
5: 2.8L I4 CYL Turbo Diesel
9: Check digit
5: 2005 Model Year
W: Toledo North Assembly
Код модели кузова: KJJH74
Двигатель: ENR 2.8L 4 Cyl Turbo Diesel Engine
Коробка передач: DGE All 5-Speed Automatic Transmissions
Модельный год: 2005
Дата производства: 10.03.2005
*N5: Cloth High-Back Bucket Seats
-D5: Med Slate Gray
142S: Zone 42-Detroit
1AAS: U.S. Dealer Retail
22C: Customer Preferred Package 22C
2TCA: Customer Preferred Package 2TC
3B2P: Customer Preferred Discount
594S: Vehicle Order Tracking
5I4S: Four Wheel Drive (4WD)/(4X4)
5I8S: Left Hand Drive (LHD)
5YAS: KJ-Vehicle Family
5ZBS: Price Class H
623S: Michigan State Code
6USS: Label - U.S. Specifications
923S: Michigan State Code
A46P: 2.8LTD Eng(ENR)/5Spd A/T 545RFE(DGQ)
AHMP: Convenience Group I
AHT: Trailer Tow Group
AJPS: Power Convenience Group
APAS: Monotone Paint
BAZS: 136 Amp Alternator
BCVP: 700 Amp Maintenance Free Battery
BRYP: Anti-Lock 4-Wheel Disc Brakes
CF5S: Rear 65/35 Folding Split Seat
CG3S: Advanced Multistage Front Air Bags**
CGUS: Child Seat Anchor System-LATCH Ready
CK3S: Plastic Swing Gate Trim Panel
CKCP: Floor Carpet
CKNS: Cargo Compartment Carpet
CKTS: Cargo Tie Down Loops
CLES: Front & Rear Floor Mats
CLHP: Cargo Trim Panel w/Storage Net
CSRS: Passenger Assist Handles
CSWS: Driver Assist Handle
CTLS: Base Door Trim Panel
CUFS: Full Length Floor Console
DGES: All 5-Speed Automatic Transmissions
DGQ: 5-Spd Automatic 545RFE Transmission
DHAP: Lock-Up Torque Converter
DHPP: Selec-Trac Full Time 4WD System
DJJS: Dana 30/186MM Front Axle
DMEP: 3.73 Axle Ratio
DRAS: Corporate 8.25 Rear Axle
ENR: 2.8L 4 Cyl Turbo Diesel Engine
GBBS: Tinted Windshield Glass
GCBS: Front Door Tinted Glass
GEGP: Deep Tint Sunscreen Glass
GEKS: Flipper Swing Gate Glass
GFAS: Rear Window Defroster
GNAS: Rear View Day/Night Mirror
GNCP: Sun Visors w/Illum Vanity Mirrors
GT9P: Power Mirrors, Fold-Away
GVBC: All Vehicles W/Power Mirrors
GWA: Power Sunroof
GXMP: Remote Keyless Entry
GXXP: Sentry Key Theft Deterrent System
HAAS: Air Conditioning
JAYS: Instrument Cluster w/Tach
JCBS: 120 MPH Primary Speedometer
JHAS: Var Intermittent Windshield Wipers
JHBS: Rear Window Wiper/Washer
JJBS: Dual Note Electric Horns
JJJS: 12V Auxiliary Power Outlet
JJMP: Auxiliary 12-Volt Rear Power Outlet
JKYS: Power Accessory Delay
JPHP: Speed Sensitive Power Locks
JPYS: Pwr Windows, Front 1-Touch Down
K1LS: STRIPE/BADGE/MOLDING/COLOR
K3LS: STRIPE/BADGE/MOLDING/COLOR
LACP: Illuminated Entry
LCDP: Map/Dome Reading Lamps
LDBP: Cargo Compartment Lamp
LHDS: Headlamp Off Time Delay
LMAS: Halogen Headlamps
LNJP: Fog Lamps
LPSS: CHMSL Lamp
LSES: Enhanced Accident Response System
MDAS: Front License Plate Bracket
MFKS: Body Color Grille
MLCS: Gray Fascias
MT2S: Trail Rated Badge
MVCS: Jeep Badge
MVDS: 4X4 Badge
MWES: Side Roof Rails
MZRP: Common Rail Diesel Badge
NAA: Federal Emissions
NB1P: Federal Tier 2, Bin 10 Emissions
NFPS: 20.5 Gallon Fuel Tank
NHKP: Engine Block Heater
NHMP: Speed Control
PS2: Bright Silver Metallic Clear Coat
QS2S: Bright Silver Metallic Clear Coat
RAAC: All Radio Equipped Vehicles
RBKS: AM/FM Compact Disc Radio w/Chgr Ctrl
RCGS: 6 Speakers
RDDS: Fixed Long Mast Antenna
SBAS: Power Rack and Pinion Steering
SCGP: Leather Wrapped Steering Wheel
SDAS: Normal Duty Suspension
SUAS: Tilt Steering Column
TBBS: Full Size Spare Tire
TBRS: Outside Tire Carrier
TR7S: P225/75R16 OWL All Season Tires
TZAP: Goodyear Brand Tires
WKBS: Matching Spare Wheel
WLDP: 16X7.0 Lux Aluminum Wheels
WLZC: All Aluminum Wheels
XCAS: Occupant Classification System
XFJP: Class III Receiver Hitch
XFKP: 7 Pin Wiring Harness
XFLP: 7 to 4 Pin Wiring Adaptor
XGGS: Grocery Bag Hooks
XJFS: Tethered Fuel Filler Cap
XPFS: Protective Coating and Remover
YAAS: Build To U S Market Specifications
YEP: Manuf Statement of Origin
YG3A: 3.5 Additional Gallons of Diesel
Z5EP: Payload Rating - 1350#
ZCKP: Spring - Left Front
ZCVP: Spring - Left Rear
ZRKP: Spring - Right Front
ZRVP: Spring - Right Rear
Андрюха вне форума
Старый 03.08.2013, 04:50   #3
Андрюха
Аватар для Андрюха
Передний мост: DJJS: Dana 30/186MM Front Axle
Передаточное число: DMEP: 3.73 Axle Ratio
Задний мост: DRAS: Corporate 8.25 Rear Axle
Блокировок нет.
Лей в оба моста Castrol 75w140. Как говорится: чем гуще - тем лучше.
В передний мост надо 1,24 литра, в задний 2,08 литра.
Передний мост: сливается через нижнюю пробку (под внутренний шестигранник), заливается через верхнюю (квадрат на 10 или 12)
Задний мост: тех. отверстие одно, закрыто резиновой пробкой. Мост надо либо вскрывать, либо откачивать масло шприцем (50 кубов, продается в аптеке + трубка). Заливать из бутылки.
Ну и еще:
Коробка у тебя 545
Раздатка 242
И должен быть подогрев картера от эл. розетки 220в.
Андрюха вне форума
Старый 03.08.2013, 08:09   #4
александр волков
Марка: ДЖИП ЛИБЕРТИ
Спасибо огромное!!!
Старый 15.08.2013, 11:14   #5
matviejus
Марка: Jeep Cherokee Sport 2.5tdi XJ
Если задний мост с LSD то MOTUL 90 PA. API GL – 5. Он уже с присадкой.
matviejus вне форума
Старый 15.08.2013, 15:01   #6
makarych81
Марка: Jeep KJ Limited 2003
Кто через сколько меняет? У меня скоро 20 тыс отходят думаю менять. И на счет свечей интервал - тоже к 20 подходит.
makarych81 вне форума
Старый 15.08.2013, 15:19   #7
Андрюха
Аватар для Андрюха
Сообщение от makarych81 Посмотреть сообщение
А это как ездить, т.е. как греть и (или) топить мосты. Надо открутить (вынуть) пробку и глянуть на масло - если прозрачное - все ОК, если темное или с эмульсией - менять. В городском режиме масло в мостах 30000 км. ходит свободно.
Свечи на нашем топливе - менять раз в 30000 км., но не факт что нужно, смотри по состоянию.
Андрюха вне форума
Старый 02.09.2013, 23:22   #8
Frapin
Марка: XJ
Сообщение от Андрюха Посмотреть сообщение
J: Jeep
9: Check digit
5: 2005 Model Year
Модельный год: 2005
-D5: Med Slate Gray
5ZBS: Price Class H
CKCP: Floor Carpet
GWA: Power Sunroof
LNJP: Fog Lamps
LPSS: CHMSL Lamp
MLCS: Gray Fascias
MVCS: Jeep Badge
MVDS: 4X4 Badge
NHMP: Speed Control
RCGS: 6 Speakers
Доброго дня!
А где берут такие шикарные расшифровки ВИНа?
Если не военная тайна?
Frapin вне форума
Старый 03.09.2013, 08:19   #9
Андрюха
Аватар для Андрюха
Сообщение от Frapin Посмотреть сообщение
Доброго дня!
Здесь после регистрации: http://www.usa-auto.ru/
Андрюха вне форума
Старый 03.09.2013, 14:41   #10
Iskander
Марка: Cherokee KJ CRD 2005 г.
А кто знает, что значит:
Это чего за дополнительные галлоны?
Iskander вне форума
Текущее время: 19:59. Часовой пояс GMT +3.
