#11 |
Марка: Grand Cherokee 4L 2004
Держите:
01 = IR thermister circuit open 02 = IR thermister circuit shorted 03 = Fan pot shorted 04 = Fan pot open 05 = Mode pot shorted 06 = Mode pot open 07 = IR sensor delta too large 08 = Reserved 09 = Reserved 10 = One of four motor drivers has drive "A" shorted to ground 11 = Engine air intake temperature bus message missing 12 = Country code bus message missing 13 = Mode motor not responding 14 = AI (Recirc) motor not responding 15 = Left temperature door not responding 16 = Right temperature door not responding 17 = Mode door travel range too small 18 = Mode door travel range too large 19 = AI (Recirc) door travel too small 20 = AI (Recirc) door travel too large 21 = Left temperature door travel too small 22 = Left temperature door travel too large 23 = Right temperature door travel too small 24 = Right temperature door travel too large 25 = Calibration check sum error 26 = Engine coolant temp bus message missing 27 = Vehicle speed bus message missing 28 = Engine RPM bus message missing 29 = OAT bus message missing 30 = Display intensity bus message missing 31 = VIN number bus message missing 32 = Raw OAT buss message missing 33 = IR thermister circuit was open 34 = IR thermister circuit was shorted 35 = Fan pot was shorted 36 = Fan pot was open 37 = Mode pot was shorted 38 = Mode pot was open 39 = IR sensor delta was too large 40 = Reserved 41 = Reserved 42 = One of four motor drivers had drive 9A9 shorted to ground 43 = Engine air intake temperature bus message missing 44 = Country code buss message missing 45 = Mode motor was not responding 46 = AI (Recirc) motor was not responding 47 = Left temperature door was not responding 48 = Right temperature door was not responding 49 = Mode door travel range too small 50 = Mode door travel range too large 51 = AI (Recirc) door travel range too small 52 = AI (Recirc) door travel range too large 53 = Left temperature door travel too small 54 = Left temperature door travel too large 55 = Right temperature door travel too small 56 = Right temperature door travel too large 57 = Calibration check sum error 58 = Engine coolant temp bus message missing 59 = Vehicle speed bus message missing 60 = Engine RPM bus message missing 61 = OAT bus message missing 62 = Display intensity bus message missing 63 = VIN number bus message missing 64 = Raw OAT bus message was missing 65 = Reserved 66 = Reserved 67 = Reserved |
