Старый 14.11.2015, 21:54   #201
Полдень
Марка: пока нет
Речь была про подшипники моста
В инструкции четко написано - минеральное и без LS компонентов
http://www.eaton.com/ecm/groups/publ.../ct_128302.pdf
Detroit Truetrac
A quality petroleum (mineral) based oil is recommended. Synthetic
oils and friction modifiers should not be used, as they will decrease
overall performance.
http://www.differentials.com/eaton-d...-truetrac-faqs
What kind of oil should I use? Can I use synthetic? Do I need friction additive/modifier? A quality petroleum/mineral based oil works best in the Truetrac units. We do not recommend synthetic oil. Friction additive/modifier is not required.
Могу скан инструкции оригинальной выложить
Полдень вне форума
Старый 16.11.2015, 10:11   #202
Полдень
Марка: пока нет
Вот кстати кусочек из бумажной инструкции Трутрака
High quality mineral or synthetic gear lubes are required for use in Dtroit Truetrac differential. Regardless of the lube type, always use a GL5 rated lube with the least amount of friction of friction modifier. Mineral lubes lacking friction modifiers (limited-slip additives) were historrically recommended for all Truetrac applications bucause friction can slightly reduce the bais ratio ( limited-slip aggressiveness) of Truetrac differential. However, to adress the continually increasing power outputs of modern powertrains, many vehicle manufacturers have switched to synthetic lubricants as a counter measure for increased axle temperatures and prolonged service intelvals. In general, consult the vehicle owner's manual for the manufacturer's recommendations for lubrication type, weight and fill volume. This will ensure lube compatibility with the seal materials and bearings user in the axle. Eaton Performance techical support is avalible for any concerns in lube selection
ну и кусочек из FAQ
What kind of oil should i use? Can i use synthetic? Do i need friction additive/modifier?
Truetrac units perform best when using GL5 mineral/petrolium based gear oil. Synthetic lubes are descouraged. DO NOT use friction modifier additives or lubes formulated with friction modifiers
Полдень вне форума
Старый 16.11.2015, 11:58   #203
ARRI
Марка: TJ 4.0
Полдень. Можешь всю инструкцию выложить, что с Трутраком пришла?
ARRI вне форума
Старый 16.11.2015, 12:11   #204
Полдень
Марка: пока нет
Отдал ее форумчанину alekssandr - он ребилдит мост
Сделают - отсканирую
Но она вся изжованная транспортной)
Полдень вне форума
Старый 16.11.2015, 12:17   #205
ARRI
Марка: TJ 4.0
Да, изжёванная подойдёт)))
ARRI вне форума
Старый 17.11.2015, 15:07   #206
Andrez
Аватар для Andrez
Марка: XJ 1994
Сообщение от Полдень Посмотреть сообщение
Detroit Truetrac
подшипники моста стало быть от синтетики горят, извините но имхо бред како йто.
что до кусочка приведенного текста, то дословно в нем сказано as they will decrease
overall performance. что означает уменьшается эффективность работы. зато трется наверное лучше. и сдохнет побыстрее. новую пораньше купите, производителю больше прибыли принесете))
для тяжелых условий рекомендуют синтетику. к нагреву она более устойчива чем минералка.
трутрак у меня в передке, назад детройт ставил. к нему насколько я помню вообще пофигу что лить, но мостовик советовал 75W140 LS по причинам озвученным выше, его и лью.
Последний раз редактировалось Andrez; 17.11.2015 в 15:11.
Andrez вне форума
Старый 17.11.2015, 18:24   #207
GR_V
Эта инструкция в моем понимании хочет донести следующую информацию:
"Синтетическое масло снижает эффективность работы блокировки."
Блокировки Dana 30 и Dana 44, в разработке Dana 35
GR_V вне форума
Старый 17.11.2015, 21:38   #208
Полдень
Марка: пока нет
Сообщение от Andrez Посмотреть сообщение
Не надо передергивать
Речь была о том что подшипники горят чаще на конкретной модели на масле 75w140. Чаще чем на 75w90
Полдень вне форума
Старый 17.11.2015, 22:47   #209
GR_V
От чего они сгорят на 75w140 ?
GR_V вне форума
Старый 17.11.2015, 23:48   #210
MOPARыш
Аватар для MOPARыш
Сообщение от GR_V Посмотреть сообщение
Да ещё если LS взять.Бред какой то.Во все свои машины(даже в первые жигули) в мосты лью 75W140.Пока небыло LSного масла добавлял мопарьевую присадку.Проблем с мостами небыло.
MOPARыш вне форума
Метки
dana, блокировка, мост, редуктор, самоблок
Текущее время: 16:32. Часовой пояс GMT +3.
