Вернуться   JEEP-FORUM.RU - ДЖИП-ФОРУМ.РФ - Форум JEEP-ов > JEEP технический раздел > Jeep Liberty > Jeep Liberty KK 2008 — 2013
Старый 09.06.2015, 20:19   #11
Андрей Rtp
Аватар для Андрей Rtp
Марка: Джип Гранд Чероки Ларедо ZJ 1994 года 4.0 42 RE? 231 раздатка.
Сообщение от Nepmann Посмотреть сообщение
Тока что проверил еще раз.
VIN:1J8GN28K99W548289 правильный в JEEP дает комплектацию аж на 5 листах
Equipment Listing
VIN 1J8GN28K99W548289
Vehicle Description 2009 JEEP LIBERTY SPORT 4X4 SPORT UTILITY 4-DR
Monotone Paint
160 Amp Alternator
600 Amp Maintenance Free Battery
Electronic Stability Control
Hill Start Assist
Anti-Lock 4-Wheel Disc Brakes
Rr 60/40 Folding Split Recline Seat
Rear 60/40 Folding Split Seat
Supplemental Side Air Bags
Child Seat Anchor System-LATCH Ready
Advanced Multistage Front Air Bags
Floor Carpet
Plastic Liftgate Trim Panel
Cargo Trim Panel
Luxury Front & Rear Floor Mats
Reversible/Waterproof Cargo Storage
Base Door Trim Panel
Full Length Floor Console
Command Trac II - Part Time 4WD
Dana 30/186MM Front Axle
3.73 Rear Axle Ratio
Corporate 8.25 Rear Axle
Conventional Differential Rear Axle
STANDARD EQUIPMENT
Tinted Windshield Glass
Flipper Liftgate Glass
Rear Window Defroster
Rear View Day/Night Mirror
Sun Visors w/Illum Vanity Mirrors
Power Mirrors, Fold-Away
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Conditioning
Instrument Panel
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Accessory Delay
Power Windows, Driver One-Touch
Speed Sensitive Power Locks
Manual Adjust Seats
BRILLIANT BLACK CRYSTAL Fender Flare
Tire Pressure Monitoring Warning LP
Illuminated Entry
Courtesy Lamps
Map/Dome Reading Lamps
Rear Dome Lamp
Cargo Compartment Lamp
Headlamp Off Time Delay
Halogen Headlamps
Automatic Headlamps
CHMSL Lamp
Enhanced Accident Response System
Front License Plate Bracket
Body Color Grille
Bodyside Molded-In-Color Moldings
Body Color Fascias
Black License Plate Brow
Trail Rated Badge
Jeep Badge
4X4 Badge
19.5 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Brilliant Black Crystal Pearl Coat
6 Speakers
Removable Short Mast Antenna
SIRIUS Satellite Radio
Power Rack and Pinion Steering
Luxury Steering Wheel
Normal Duty Suspension
Tilt Steering Column
Occupant Classification System
Tethered Fuel Filler Cap
Protective Coating and Remover
Instrument Panel Parts Module
Door Parts Module
Front End Parts Module
Front Suspension Parts Module
Rear Suspension Parts Module
Front Suspension Damper Parts Module
Build To U.S. Mkt. Specifications
GVW Rating - 5600#
U.S. Dealer Retail
Zone 32-New York
KK/5752 Vehicle Family
Four Wheel Drive (4WD)/(4X4)
Price Class L
Left Hand Drive (LHD)
2009 Vehicle Specifications
Vehicle Order Tracking
U.S. Specifications Label
New York Ship to State Code
Carb. Code 04
Smog Code 05
New York Sold to State Code
Premium Cloth Bucket Seats
Dark Slate Gray
Trailer Tow Class III Group
Rocky Mountain Edition Group
Trailer Tow Group
Popular Equipment Group
Smoker's Group
Brake Assist
Hill Descent Control
All Speed Traction Control
Trailer Sway Control
OPTIONAL EQUIPMENT
Front Passenger Fold Flat Seat
Cargo Compartment Cover
Removable Ash Tray
Overhead Console
4-Spd. Automatic VLP 42RLE Trans
3.7L V6 Engine
Deep Tint Sunscreen Glass
All Vehicles W/Power Mirrors
Power Sunroof
Temperature & Compass Gauge
Cigar Lighter
115V Auxiliary Power Outlet
Fog Lamps
Black Side Roof Rails
3.7L Badge
Rocky Mountain Edition Badge
California Emissions
Power Steering Cooler
Speed Control
Heavy Duty Engine Cooling
Media Center 430 CD/DVD/MP3/HDD
Full Size Spare Tire
P235/65R17 VSB All Season Tires
Goodyear Brand Tires
17X7.0 Alum Silver Accent Wheels
Black Steel Spare Wheel
All Aluminum Wheels
Tip Start
Class III Receiver Hitch
7 Pin Wiring Harness
7 to 4 Pin Wiring Adaptor
Stain Repel Seat Fabric
For More Info, Call 888-539-7474
1-Yr. SiriusXM Radio Service
Manuf Statement of Origin
5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
41003-112 Mga 0Au
FAM: DH TRACKING: 50810T10 MY:2006
Customer Preferred Package 2TW
Customer Preferred Package 28W
Includes Full Tank of Fuel
Special Scheduling Condition VII
дай ссылку на сайт
Андрей Rtp вне форума
Старый 09.06.2015, 20:23   #12
Nepmann
Марка: Jeep Liberty Sport 2009
http://www.jeep.com/webselfservice/B...GN28K99W548289
Добавлено через 2 минуты
Если не трудно помогите с парт-номерами.
нужны номера деталей - петля заднего стекла. бензиновый фильтр. и в багажнике на полу крышка, в ней две прорези под петельки на пружинке. Вот одна полностью разломана вместе с основанием. по каталогу 05142 350AB но ни один американский интернет магазин не определяет этот номер((((
Nepmann вне форума
Старый 10.06.2015, 02:02   #13
Nepmann
ездил на сервис сегодня. приговорили рейку рулевую(
немного туговато крутить руль и подтекает немного.
вот тоже задача. менять рейку на новую или есть ремкомплекты?
Nepmann вне форума
Старый 12.06.2015, 04:26   #14
Nepmann
и тишинаа. Что с номерками деталек никто не подсобит?
Nepmann вне форума
Старый 12.06.2015, 08:37   #15
Андрюха
Аватар для Андрюха
Марка: KJ '03 Limited 3.7 - был
Скачай каталог запчастей на KK отсюда: http://jeep4x4club.ru/files/file/35-...p-kk-2008-god/
Насколько я понял на KK с бензиновым двигателем топливного фильтра нет в принципе (в каталоге такой позиции нет), а вот на дизельном KK он есть.
Петля заднего стекла: http://www.ebay.com/itm/Right-side-l...a1f53d&vxp=mtr - правая, найдена опытным путем, т.к. в каталоге её отдельно нет, только вместе со стеклом.
По номеру 05142350AB: http://www.ebay.com/itm/New-OEM-Mopa...7e7413&vxp=mtr
Добавлено через 5 минут
Про рейку так: если руль туго крутится, то вполне возможно что прежний владелец зажал рейку регулировочным болтом до упора, т.е. выработка на шестернях уже есть, а значит менять надо рейку целиком.
Посмотри б/у на разборках, вот например: http://www.ebay.com/itm/07-08-09-10-...5eedec&vxp=mtr
ЗЫ: Nepmann, ты сам то откуда?
Андрюха вне форума
Старый 13.06.2015, 06:07   #16
Nepmann
спасибо за конкретику.
Сам с Москвы. Но щас на карибах.. Машинку тут прикупил.
Добавлено через 16 минут
еще вопросик.
в багажнике на полу встроенный ящик с крышкой. на основании ящика по бокам есть две держалки на пружинке для крышки. Вот одна вырвана с корнем из основания. Посмотрел номер детальки 05142 350AB. [URL="http://parts.sutiendamopar.com/showAssembly.aspx?ukey_product=42340561&ukey_assem bly=5625323"]Очень уж дорогая ...(
Может кто знает аналог побюджетнее? или оригинал подешевле где купить?
Nepmann вне форума
Текущее время: 00:57. Часовой пояс GMT +3.
