25.01.2019, 12:35 | #1212 | |
Марка: Jeep ZJ 2.5TD 98г +2"
26.02.2019, 14:02 | #1215 |
Марка: ZJ '96 (5.2 Limited Canada)
не уверен в правильности:
Отчёт NHTSA (?) LINCOLN Navigator, 2004 5.4 л, 223.71 кВт (304.16 лс) VIN 5LMFU28R64LJ02414 Error Code 0 - VIN decoded clean. Check Digit (9th position) is correct Make LINCOLN Manufacturer Name FORD MOTOR COMPANY, USA Model Navigator Model Year 2004 Plant City Wayne Vehicle Type MULTIPURPOSE PASSENGER VEHICLE (MPV) Plant Country United States (USA) Plant Company Name Michigan Truck Plant State Michigan Manufacturer Id 976 Body Class Sport Utility Vehicle (SUV)/Multi Purpose Vehicle (MPV) Doors 4 Gross Vehicle Weight Rating Class 2F: 7,001 - 8,000 lb (3,175 - 3,629 kg) Drive Type 4WD/4-Wheel Drive/4x4 Brake System Type Hydraulic Engine Number of Cylinders 8 Displacement (CC) 5400.0 Displacement (CI) 329.52821811155 Displacement (L) 5.4 Engine Power (KW) 223.7100 Fuel Type - Primary Gasoline Valve Train Design Dual Overhead Cam (DOHC) Engine Configuration V-ShapedEngine Brake (hp) 300 Engine Manufacturer Ford Seat Belts Type Manual Curtain Air Bag Locations 1st Row (Driver & Passenger) Front Air Bag Locations 1st Row (Driver & Passenger) Side Air Bag Locations 1st Row (Driver & Passenger) |
21.05.2019, 05:32 | #1219 | |
Марка: Jeep Grand Cherokee ZJ 96год, 3,5", 5,2, NV249OD, 44RE
Хороший внешний вид не гарантирует примерное поведение Последний раз редактировалось deb; 21.05.2019 в 05:35. |
