Старый 21.09.2009, 22:26   #1
tahoe
Аватар для tahoe
По умолчанию Варианты Лифт китов
2-2.5 Inch Lift Options
RE6160 XJ 2" Budget Boost w/shocks
Tire Clearance: 30x9.50
Includes: Break Lines, AAL, Spacers, and Shocks
http://www.jeepinoutfitters.com/scri...?idproduct=112
OME 2" Suspension Kit, Cherokee, 1984-01
Includes: Bumpstops, Full Leaf Packs, Coils, Shocks, JKS Quicker Disconnects
http://www.jeepinoutfitters.com/scri...?idproduct=645
Superlift 2.5" Suspension lift, Jeep XJ Cherokee
Includes: Coils, Lower link arms, AAL, and Shocks
http://www.jeepinoutfitters.com/scri...?idproduct=781
Rustys 2" XJ AAL Kit
Includes: Coils, AAL, and Shocks
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=200AL&Category_Code=sus_xj_kit
Rough Country 1.5" Suspension Kit
Includes: Coils, Shackles, and Shocks
http://www.roughcountry.com/jeep_xj_1.html
Rock Lizard Fabrications 2" AAL Kit
Includes: Coils, Long AAL, Leaf Spring Clamps, Center Pins, and U-Bolts
http://www.rocklizardfabrications.co..._lift_kits.htm
Rock Lizard Fabrications 2.5" Leaf Pack Kit
Includes: Four Leaf Spring Pack, Coils, Long AAL, Spring Isolators, Spring Clamps, Center Pins, and U-Bolts
Skyjacker 2 in. Poly Value Kit
Includes: Poly Spacers, Bumpstops, Shackle and Nitro Shocks
http://www.4wheelparts.com/PDT55375.aspx
Rustys 2" Budget Boost w/Shackle
Includes: Poly Spacers, and Shackle
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=XJ-B1&Category_Code=sus_xj_kit
Rustys 2" Budget Boost w/AAL
Includes: Poly Spacers, and AAL
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=XJ-B3&Category_Code=sus_xj_kit
3-3.5 Inch Lift Options
RE6030 XJ 3.5" SuperFlex kit w/leafs
Tire Clearance: 31x10.50
Includes: Gen2 Disconnects, Coils, Bumpstops, Leaf Spring Pack, Rear break line, U-Bolt Kit, and LCA
http://www.jeepinoutfitters.com/scri...?idproduct=115
RE6010 XJ 3.5" SuperFlex kit w/aal's
Includes: LCA, Coils, Bumpstops, AAL, and Shocks
http://www.jeepinoutfitters.com/scri...?idproduct=120
RE6025 3.5" XJ Super Ride w/ Rear Springs
Includes: LCA, Full Leaf Packs, Coils, and Rear Break Line
http://www.jeepinoutfitters.com/scri...?idproduct=219
RE6020 3.5" XJ Super-Ride Kit
Includes: LCA, AAL, Coils, and Rear Break Line
http://www.jeepinoutfitters.com/scri...?idproduct=218
OME 3" Suspension Kit, Cherokee, 1984-01
Includes: Shocks, Full Spring Packs, Coils, and JKS Quicker Disconnects
http://www.jeepinoutfitters.com/scri...?idproduct=429
Rustys 3" Spring Pack Kit
Includes: Coils, Full Spring Packs, Break Line Relocation Kit, and Shocks
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=300SP&Category_Code=sus_xj_kit
Rustys 3" XJ Add-A-Leaf Kit
Includes: Coils, AAL, Break Line Relocation Kit, and Shocks
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=300AL&Category_Code=sus_xj_kit
Rough Country 3" Suspension Kit, Full Spring Pack
Includes: Coils, Full Spring Pack, and Shocks
http://www.roughcountry.com/jeep_xj_3.html
Rough Country 3" Suspension Kit, AAL
Pro Comp 3" Suspension System
Includes: Coils, AAL, Break Lines, LCA, and Adjustable Shocks
http://www.4wheelparts.com/PDT1764.aspx
Includes: Coils, AAL, Break Lines, LCA, and Non Adjustable Shocks
http://www.4wheelparts.com/PDT1566.aspx
Rancho 3 in. Suspension Kit with RS5000Shocks
Includes: Coils, Full Leaf Pack, and Shocks
http://www.4wheelparts.com/PPT3657T5491.aspx
Skyjacker 3 in. Standard Kit w/AAL
Includes: Coils, AAL, and Hydro Shocks
http://www.4wheelparts.com/PDT54900.aspx
Skyjacker 3 in. Standard Kit w/ Full Spring Pack
Includes: Coils, Full Spring Pack, and Hydro Shocks
http://www.4wheelparts.com/PDT55240.aspx
Full Traction 3.5" Kit
Includes: Coils, Quick Disconnects, Rear Break Line, Dual Rear Leaf Inserts, and Control Arms
http://www.full-traction.com/detail....=1&PRODUCTID=9 7&NOTES=20
Warrior 3" Suspension Kit
Includes: Shocks, Shackles, Coils, AAL, Sway Bar Link, Tie Rod Bracket, and LCA
http://www.discountjeepparts.com/pro...3b0a2381eb6115
Rock Krawler 3" Suspension Kit
Includes: Coils, AAL, Adj Front Trac Bar, Trac Bar Relocation Bracket, Drop Pitman Arm, Sway Bar Discos, and U Bolts
http://www.tellico4x4.com/product_in...ducts_id/28396
Black Diamond 3" Suspension Kit w/ AAL
Includes: Coils, Shocks, Full AAL's, and LCA's
http://www.4wheelerssupply.com/catal...oducts_id/1581
4-4.5 Inch Lift Options
RE6130 XJ 4.5" SuperFlex kit w/leafs
Tire Clearance: 32x11.5
Includes: Coils, Full Spring Pack, Bumpstops, Front Track Bar, LCA, Rear Break lines, and RE Gen2 Disconnects
http://www.jeepinoutfitters.com/scri...?idproduct=113
RE6111 XJ 4.5" SuperFlex kit w/AAL
Includes: Coils, AAL, Bumpstops, Front Track Bar, LCA, and Break Lines
http://www.jeepinoutfitters.com/scri...?idCategory=62
Superlift 4" RockRunner lift kit, Jeep XJ Cherokee
Includes: Coils, Full Spring Pack, Shocks, Upper and Lower axle links, Front Track Bar, and Quick Disconnects
http://www.jeepinoutfitters.com/scri...?idproduct=783
Superlift 4" Standard lift kit, Jeep XJ Cherokee
Includes: Coils, Full Spring Pack, Shocks, Front Track Bar, Upper and Lower axle links, and Quick Disconnects
http://www.jeepinoutfitters.com/scri...?idproduct=782
Rustys 4.5" XJ Spring Pack Kit
Includes: Coils, Full Spring Pack, Shocks, LCA, Break Lines, Front Track Bar, TC Drop Kit, and Front Sway bar Extensions
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=405K&Category_Code=sus_xj_kit
Rustys 4.5" XJ Add-A-Leaf Kit
Includes: Coils, AAL, Shocks, Rear Shackles, LCA, TC Drop, Brake Lines, and Sway Bar Extensions
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=405AL&Category_Code=sus_xj_kit
Rough Country 4.5 Suspension Kit w/AAL
Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, AAL, and Shackles
http://www.roughcountry.com/jeep_xj_4.html
Rough Country 4.5 Suspension Kit w/ Full Spring Kit
Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, and Full Spring Pack
Fabtech 4 in. Performance Kit
Includes: Coils, Rear AAL, Rear Shackle, Extended Sway Bar Links, and Shocks
http://www.4wheelparts.com/PPT1906T5491.aspx
Rock Krawler 4.5" Short Arm Flex Lift Kit
Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, and Rear Shims
http://www.jackit.com/manufacturer/r..._sa.htm#xj45sa
Rock Krawler 4.5" X Factor Short Arm Kit
Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, Adj Trac Bar, and Shims
http://www.tellico4x4.com/product_in...ducts_id/24145
Rock Krawler 4.5" X Factor Plus Long Arm Kit
Includes: Leafs, Coils, High Adj LCA's, Long Arm Brackets, UTA, Adj Track Bar, Trac Bar Relcoation Bracket, Break Lines, Sway Bar Discos, and Rear U Bolts
http://www.tellico4x4.com/product_in...ducts_id/24146
5-5.5 Inch Lift Options
RE6200 XJ 5.5" Extreme Duty lift
Tire Clearance: 33x12.50
Includes: Coils, Full Spring Pack, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, and Break Lines
http://www.jeepinoutfitters.com/scri...?idproduct=111
RE6300 5.5" XJLA Extreme Duty
Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, Break Lines, and Long Arm Conversion
http://www.jeepinoutfitters.com/scri...?idproduct=388
T&T Customs XJ 5.5" Y-Link Suspension System
Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Belly Pan, Shock Mounts, Drop Pitman arm, Unibody Bracing System, Shackles, and Sway Bar Disconnects
http://www.jeepinoutfitters.com/scri...?idproduct=681
DPG 5” Suspension System
http://dpgoffroad.com/xjtrailgunner.htm
6-6.5 Inch Lift Options
Rustys 6.5" XJ/MJ Long Travel Suspension Kit
Tire Clearance: 34x12.50
Includes: Coils, Full Spring Packs, Shocks, Trac Bar, JKS Sway Bar Disconnects, and Break Lines
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=605LT&Category_Code=sus_xj_kit
Rustys 6.5" XJ Spring Pack Kit
Includes: Coils, Full Spring Pack, Trac Bar, UCA, LCA, Break Lines, JKS Sway Bar Disconnects, and Shocks
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=605K&Category_Code=sus_xj_kit
Rough Country 6.5” Suspension Kit
Includes: Coils, Full Spring Pack, UCA, LCA, TC Drop Kit, Track Bar, Sway Bar Disconnects, Pitman Arm, and Shocks
http://www.roughcountry.com/jeep_xj_6.html
Skyjacker 6 in. Rock Ready Kit
Includes: Coils, Full Spring Pack, Pitman Arm, and Hydro Shocks
http://www.4wheelparts.com/PDT54902.aspx
Full Traction 6" Kit
Includes: Coils, Full Spring Pack, Long Arms, Quick Disconnects, Track Bar, and LCA
http://www.full-traction.com/detail....=1&PRODUCTID=9 8&NOTES=9,10
Rock Krawler 6.5" X Factor Plus Long Arm
http://www.tellico4x4.com/product_in...ducts_id/24151
8 Inch Lift Options
Skyjacker 8" Rock Ready Kit
Tire Clearance: 36
Includes: U-bolts, Double Flex lower control arms, Front brake hoses, Rear brake hoses, Dropped pitman arm, New control arm mount brackets and frame, Rear sway bar end links, Rear shackles, Front bumpstop spacers, Rear bumpstop spacers, Flex series upper control arms, Front sway bar links, Front track bar with steering stabilizer, Rear leaf springs, and Dana 30 cradle and brackets
http://www.4wheelerssupply.com/catal...cc1596c1c189fc
Rock Krawler 8" X Factor Plus Long Arm
Tire Clearance: 36
http://www.tellico4x4.com/product_in...ducts_id/24152
Rock Krawler Super 8.0" Plus with Rear Coil Over Conversion
Tire Clearance: 36
Includes: Double Adj LCA'a, Long Arm Brackets, UTA, Torque Arm Bracket, Adj Trac Bar, Trac Bar Relocation Bracket, Rear UCA, Rear 4 Link Mounting Cable, Coil Over Mounting Brackets, Break Lines, Rear Shocks, and Front Quick Discos
http://www.tellico4x4.com/product_in...ducts_id/24087
Rustys 8" XJ Long Travel Suspension Kit
Tire Clearance: 36
Includes: Leafs, Coils, Shackles, Shocks, Drop Pitman Arm, Trac Bar, JKS Discos, and Front ans Rear Break Lines
http://rustysoffroad.com/mm5/merchan...rustys&Product _Code=800LT&Category_Code=sus_xj_kit
Jeep Cherokee XJ 4L, 242, 92г.в., Rusty's 4.5", 4:56 gears, TSL 33"
ZJ 4L, 231, 94г.в.,31"
Chevrolet Tahoe 5,7L
tahoe вне форума
Старый 21.09.2009, 22:31   #2
Калёк
Марка: Jeep Cherokee 4L . Grand Cherokee 5.2
дааааааа постарлся
Калёк вне форума
Старый 21.09.2009, 23:36   #3
Иван АндреичЪ
Аватар для Иван АндреичЪ
Вот за это спасибо
"97 Cherokee 2.5TD
Иван АндреичЪ вне форума
Старый 22.09.2009, 00:00   #4
Аксён
Профессиональный ломатель
Аватар для Аксён
Как говорится, плюс ТЫСЧА!
Очень полезный и наглядный набор ссылок.
Два -чайник на кухне.
Три литра-банка огурцов.
Аксён вне форума
Старый 22.09.2009, 00:28   #5
Pavlo
Аватар для Pavlo
Все супер, только у меня некоторые ссылки не работают. . .
8(926)269-61-55
Pavlo вне форума
Старый 22.09.2009, 00:35   #6
Иван АндреичЪ
Да...и у меня тоже. Реаботают,но там пусто...
"97 Cherokee 2.5TD
Старый 22.09.2009, 08:26   #7
admin
Аватар для admin
Марка: cherokee XJ 2D
не кислый подбор брендовых китов
JEEP-Forum - Мы объединяем...
эпичные цитаты pirate4x4.com:
Go Big or go home ! (....)
info@jeep-forum.ru
admin вне форума
Текущее время: 22:22. Часовой пояс GMT +3.
