Марка: Jeep Grand Cherokee Limited 4.0 ZJ
Блин. А ведь точно... Что то я проеб...ил )) тогда ещё не легче что за 207 раздатка??))
"Там где пехота не пройдёт и бронепоезд не промчится, Гарик 69 на Грандюхе проползёт и не х..я с ним не случится... "![]() 89000122-ОДЫН-ОДЫН-ОДЫН)))
#2 | |
Марка: ХJ, полмотора.
"NP207: "Command-Trac", Part-Time only, 2.61:1 ratio low The NP207 has a aluminum case and an appearance similar to the NP231. It should have a tag on the back saying New Process Gear, Model 207. This chain driven transfer case uses a 21 spline input with the manual transmissions and a 23 spline input with the automatic transmissions. The output for the front driveshaft is on the drivers side. Low range is 2.61 and high is 1.00. This transfer case is widely scorned. The NP207 was used in the first year of Wranglers in 1987. It was used in Cherokees (XJ) until from '84-'87" |
