Старый 01.10.2015, 10:48   #11
Андрюха
Аватар для Андрюха
Марка: KJ '03 Limited 3.7 - был
Повторюсь: мне поддон меняли в обычном гараже без снятия двигателя с помощью двух домкратов за пару часов. Возможно что откручивали опоры двигателя.
Добавлено через 52 секунды
Да, не забудьте прикупить новую прокладку - успокоитель масла.
Добавлено через 4 минуты
Манул говорит так: REMOVAL - 4x4
(1) Disconnect Battery.
(2) Install Engine Support Fixture, special Tool
8534.
(3) Raise and support vehicle.
(4) Remove front wheel and tire assemblies.
(5) Remove skid plate (if equipped).
(6) Drain engine oil.
(7) Remove engine to transmission structural
cover, (if equipped).
(8) Remove transmission oil cooler line bracket.
(9) Remove the front axle assembly from the vehi-
cle(Refer to 3 - DIFFERENTIAL & DRIVELINE/
FRONT AXLE - REMOVAL).
(10) Loosen both engine mount through bolts.
(11) Lower the vehicle.
NOTE: It is not necessary to remove the viscous
fan , or fan shroud, for oil pan removal.
(12) Raise the engine using Engine Support Fix-
ture, special Tool 8534, until the viscous fan almost
touches the fan shroud.
(13) Raise the vehicle.
(14) Remove the oil pan bolts.
(15) Separate the oil pan from the engine.
(16) Remove the (2) nuts and (1) bolt holding the
oil pump pick-up tube, and windage tray in place.
NOTE: It will be necessary to move the oil pan from
side to side to gain access to these fasteners.
(17) Drop the oil pump pick-up tube into the oil
pan, and remove the oil pan, pick-up tube, and the
windage tray, as an assembly, from the front of the
vehicle.
Андрюха вне форума
Текущее время: 05:15. Часовой пояс GMT +3.
