Старый 28.08.2013, 13:30   #1
По умолчанию Спецификация ZJ
Весы, массы и тд и тп, полезная инфа.
http://www.cherokeeforum.com/f52/zj-...fications-819/
ZJ Grand Cherokee Stock Specifications
This is a stock specification sheet for the ZJ, if you find there is anything that you would like to add please send me a PM and I will do so.
Dimensions
Jeep ZJ Produced from 1993-1995
Exterior Dimensions:
Length: 176.7 in. Width: 69.2 in.
Height: 64.9 in. Wheel Base: 105.9 in.
Ground Clearance: 8.2 in. Curb Weight: 3574 lbs
Interior Dimensions:
Front Head Room: 39 in. Front Hip Room: 56.9 in.
Front Shoulder Room: 58.2 in. Rear Head Room: 39 in.
Rear Shoulder Room: 57.6 in. Rear Hip Room: 49.3 in.
Front Leg Room: 40.8 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.1 cu. ft. Maximum Cargo Capacity: 80 cu. ft.
Maximum Seating: 5
Performance:
Base Number of Cylinders: 6 Base Engine Size: 4 liters
Base Engine Type: Inline 6 Horsepower: 190 hp
Max Horsepower: 4750 rpm Torque: 225 ft-lbs.
Max Torque: 4000 rpm Maximum Payload: 1150 lbs.
Maximum Towing Capacity: 5000 lbs. Drive Type: RWD
Turning Circle: 36.6 ft.
Optional Engine - 5.2 MPI V8 (MPI stands for Multi-Port Injection)
Horsepower:220
Fuel Tank Capacity: 23 gal.
EPA Mileage Estimates: (City/Highway) for 6cyl
Manual: 16 mpg / 21 mpg Automatic: : 15 mpg / 20 mpg
Range in Miles: (City/Highway)
Automatic: 345 mi. / 460 mi. Manual: 368 mi. / 483 mi.
1996-98 ZJ Dimension changes - (If not shown, it did not change)
Exterior:
Length: 177.2 in. Width: 69.3 in.
Ground Clearance: 7.7 in. Curb Weight: 3926 lbs.
Interior:
Front Head Room: 38.9 in. Front Hip Room: 56.7 in.
Front Shoulder Room: 59.2 in. Rear Head Room: 39 in.
Front Leg Room: 40.9 in. Rear Leg Room: 35.7 in.
Luggage Capacity: 40.9 cu. ft. Maximum Cargo Capacity: 79 cu. ft.
Maximum Seating: 5
Performance Data
Performance for 6 cyl:
Acceleration (0-60 mph): 8.6 sec. Braking Distance: 138 ft.
Road Holding Index: .75 g Base Number of Cylinders: 6
Base Engine Size: 4 liters Base Engine Type: Inline 6
Horsepower: 185 hp Max Horsepower: 4600 rpm
Torque: 220 ft-lbs. Max Torque: 2400 rpm
Maximum Payload: 1150 lbs. Turning Circle: 37.5 ft.
1998 5.9 Limited Performance: (Available only in 1998)
Performance
Acceleration (0-60 mph): 7.1 sec. Braking Distance: 135 ft.
Road Holding Index: .75 g Base Number of Cylinders: 8
Base Engine Size: 5.9 liters Base Engine Type: V8
Horsepower: 245 hp Max Horsepower: 4000 rpm
Torque: 345 ft-lbs. Max Torque: 3200 rpm
Maximum Payload: 1150 lbs. Maximum Towing Capacity: 5000 lbs.
Drive Type: 4WD Turning Circle: 37.2 ft.
Fuel Data
Automatic: : 13 mpg / 16 mpg
Automatic: 299 mi. / 368 mi.
Trim Packages
ZJ/WJ trim models, listed from lowest priced to highest.
1993- Base, Laredo, Grand Wagoneer, Limited,
1994- SE, Laredo, Limited
1995- SE, Laredo, Limited, Orvis Limited
1996- Laredo, Limited
1997- Laredo, Tsi, Limited
1998- Laredo, Tsi, Limited, 5.9 Limited
Updates:
1994 - Limited gets rear disc brakes instead of drums used on all 1993, and 1994 Laredo Models.
1995- 2WD is offered in Limited trim, disc brakes for all trim models.
1996- 2WD is offered in both Laredo and Limited, 6 and 8 cylinder models.
1998- 5.9 Limited is offered, and only has a single year of production.
Engines
* 1993–1995 4.0L 190 hp (142 kW)
* 1996–1998 4.0L AMC Power Tech I6 185 hp (138 kW)
* 1993–1998 5.2L Magnum V8 220 hp (164 kW) 285 ft·lbs (386 N·m)
* 1998 5.9L Magnum V8 245 hp (183 kW) 345 ft·lbs (468 N·m) Limited
Transmissions
*46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines.
*44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines.
*42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
*46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines
*AX-15 5 spd. manual transmission used in 1993 - 94 Jeep Grand Cherokees with 4.0L engines.
*AW4 Automatic transmission used in 1993 with 4.0L engines
Axles
Front: The Dana 30 was used on all ZJ's (3:55)
Rear: The c-clip Dana 35 was on all non towing package ZJ's.
The Dana 44a was used with a v8 and a tow package through 95.
The Dana 35 c clip was available with 3.73s and a LSD
Transfer Cases
NP242 used on I6 ZJs and WJs - This is known as SelecTrac NOTE: 93-94 V8 ZJ's had option of the NP242 Selec-Trac t-case.
NP249 used on all V8 ZJs and WJs, and was optional on 6 cylinder models - This is known as QuadraTrac.
NP 231 used on various HD ZJ and WJ V8s - known as Command-Trac
Also in 93-94 NP231 Command Trac was available with the I6's in SE's and Laredo's.
2002 - Quadra-Trac II introduced as option on V8s- known as Quadra-Drive, this is an AWD system similar to Audis and Subarus.
Tire Size
Largest tires you can fit on a stock Grand are 30X9.5
With a budget boost you can fit 31X10.5 (some minor trimming.)
You need 3.5 to clear 32's (additional trimming ..Minor that is..)
4.5 will clear 33's (this will require some serious trimming..)
ZJ Fuse List
#1: 20 amp--Power Ant. Tow Relay
#2: 15 amp.--Brake lamps
#3: 20 Amp--Hazard Lamps
#4: 15 amp--Security Lamp
#5: 15 amp--Interior lighting
#6: 5 amp--Security alarm module
#7: 15 amp--Security alarm relay , flash to pass
#8: 15 amp--OVerhead console , Keyless entry radio memory clock chime module , power locks, power mirrors, hevac and VIC
#9: 20amp--Rear wiper
#10: 10amp--Radio Accesory
#11: 15amp--Cigarette lighter
#12: 15amp--Parking lamps, automatic headlights
#13: 20amp--Horn Relay
#14: 20amp--Power lock relay
#15: 3amp--ABS Module and relay
#16: 20amp--Turn signal
#17: 7.5amp--Heater and air conditioner module
#18: 15amp--Airbag module
#19: 15amp--interior mirror,auto headlight,overhead console,VIC/GDM Module, Heated Rear window, illuminated entry and chime module
#20: 10amp--Heated rear window switch, overdrive switch, speed control
#21: 15amp--Security alarm module,Lamp outage module
#22: 15amp--Airbag module, speedometer,tachometer, telltales and gauges
#23: 15amp--Heated mirror feed,Heated rear window switch
#24-7.5amp--Instrument panel illumination
#25-30amp circuit breaker--Power seats
#26-30 amp circuit breaker--Power windows
#27-10 amp circuit breaker--Security alarm module and front wiper
#28-30amp--Heated rear window relay
Special thanks to Orangeamc13 for supplying this information.
Старый 28.08.2013, 14:47   #2
Оттуда:
Емкость топливного бака: 23 галлонов.
Расход топлива: (город / трасса) для 6 цилиндрового
Ручная коробка: 16 миль на галлон / 21 миль на галлон
Автоматическая коробка: 15 миль на галлон / 20 миль на галлон
Пробег на баке в милях: (город / трасса)
АКПП: 345 миль. / 460 миль.
Ручная КПП: 368 миль. / 483 миль.
Последний раз редактировалось Skydive; 28.08.2013 в 15:19.
Старый 28.08.2013, 16:36   #3
John Dreik
Аватар для John Dreik
один из лучших каталогов по Jeep.почти все модели и полные спецификации http://www.automobile-catalog.com/list-jeep.html
John Dreik вне форума
Текущее время: 06:43. Часовой пояс GMT +3.
